98 Camaro Missfires
98 Camaro Missfires
I have a 98 Camaro,3.8.I got a P0301 code. Replaced plugs, wires&coil packs on all cylinders. Still getting same code. Car wants to bog out at about 2500 RPMs. Do you have any idea what might be the problem?
PCM sees #1 cylinder misfiring. Since you already replaced the ignition stuff, check that the injector for #1 cylinder is firing properly (use NOID lights). Also check compression (bad compression = misfire).
