'95 Camaro Bose Radio clock won't go off - ever
I assume there is a short or whatever in the radio. Also, I think there is a drain elsewhere. I disconnected the radio altogether and still could tell there was a drain because (w/brand new battery) it would not start if the car sat for more than a day, day and 1/2. I don't really know how to troubleshoot this problem so if anyone has advice on easiest-noob method(s) I would appreciate it. Also, my alternator, drivers seat switch went out around the same time and my window motor went out to boot - rains, it pours I guess.
My buddy that I got the car from a few years ago also said that the dealer disconnected the viper alarm (brain/box/?) because it caused undo drain on system when he first got the car. It just seems like this car leaks energy everywhere. Are these common issues with '95 Camaros? Thanks for any advice. |
RE: '95 Camaro Bose Radio clock won't go off - ever
No, I think this problem is specific to whatever modifications where made to this car - best to figure out what was done, and check those connections...
Coincidence or what.
I have the same problem with my radio and had weird stuff happen aswell. window motor stopped working and car drains every 2-3 days. map reading lights under the morror wouldn't go off. i,ve sorted the map lights but still have the drain problem. tried connecting a bulb between the battery and the car and esting each circuit for a problem but can't find one. I have the passII immobiliser and that works ok. Mines a 95 also!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! [IMG]local://upfiles/9443/212085879AC54B30867AEF3E68138FD4.jpg[/IMG] |
