95 camaro 3.4 wont start
HELP!!!
My 95 camaro wont start i have checked fuel psi a ind its good checked spark and thats good i even sprayed a little either in it and it acted like it wanted to start but it wouldnt
Im at my wits end with this damn car . Oh also had it checked with a computer for codes and no codes at all. Someone please help.
moved your thread to the 4th gen v6 section. welcome to the forum. sometime when you cant sleep read the rules.
enjoy. oh and look here https://camaroforums.com/forum/93-02...18/#post618955
could it possibly be the starter or battery. any ignition fuses. half the time a problem with a car is something stupid, so always check the obvious first. then when they check out, move on to the more in depth things. also check your throttle cable. if that popped off, the car isnt going to start. otherwise it might be the MAF sensor, fuel pump, icm. there are a number of reasons for a car not starting.
im guessing since it seemed like it wanted to start with the spray, it will still crank, just not actually run?
my guess as well is if it tried with the spray, a problem with the fuel would seem to be it. the psi in the line might be correct, but is it stagnant pressure?
(i hope i wasnt confusing, i have a problem wording things the right way as Ive been told numerous times) Just trying to help. Hope I brought up something for you.
basically im just going on the question itself. if you add some details about exactly all that you have checked so far, what exactly it is doing under each condition, whats been replaced on the car before, any bit of information you can give; we can probably come up with a better answer for you.
