95 3.4 pinion seal
Old Oct 1, 2009 | 11:21 AM
thetal1's Avatar
Default 95 3.4 pinion seal
my pinion seal has been bad for a while. How much work would it be to replace it?
Old Oct 3, 2009 | 10:33 AM
Jonny Dubyah's Avatar
i had a post here but edited it because im a retard and am pretty sure i was way off in left feild lol so good luck with the issue and sorry for the false hope haha
Old Oct 5, 2009 | 11:50 AM
Masospaghetti's Avatar
There's actually two pinion seals, an inner and outer. The outer can be done, if I remember right, by removing the driveshaft. The inner requires you to remove the differential (and disassembling the pinion shaft) which is a lot of work, especially since it requires some special tools to do correctly.
I had a mech rebuild my diff for $450, it might be worth doing if its leaking really bad.
Old Oct 5, 2009 | 11:58 AM
im showing two bearings and one seal 93 gm part #26026792. looks like the seal should not be to tough. u will need to be able to get the yoke off so a puller will be needed.
Old Oct 5, 2009 | 11:59 AM
thetal1's Avatar
alright that seems like its a little out of my hands cuz i have a cheap tool set and thats about it. how much should it cost for someone to fix this?
Old Oct 5, 2009 | 12:06 PM
call or go to your local dealer and ask. should not be that much or take that long. im thinkin a hundred bucks but the costs nowdays are crazy going up.
Old Oct 5, 2009 | 04:10 PM
Sorry, you're right, there's two bearings but one seal. I think the seal is replaced from the outside, no?
Old Oct 5, 2009 | 05:27 PM
thetal1's Avatar
ok another question is how much would a tranny all the way to the rear end from a z28 cost and would it all fit? I figure that if i just got a rear end from a z28 that worked it would just fix alot of problems and this pinion seal thing.
Old Oct 6, 2009 | 01:56 PM
I don't think the T56 trans will bolt up to a 3.4/3.8, but the driveshafts and rear ends are interchangable. The Z28 driveshafts are sometimes aluminum too, which is better than the steel ones and definitely better than the 2-piece steel units that the V6's came with.
Old Oct 6, 2009 | 06:31 PM
yes but u need to take the yoke off.
