94 3.4 misfire issue
my 94 3.4 suddenly has a major misfire issue mostly under load. have replaced plugs,wires,coil packs and ignition module. when i pull wires for spark test # 1 shuts the engine down and will not restart until reconnected. could the pcm be bad or the crank sensor thanks for the help
test fuel pressure
