3.4L Changing Thermostat Inquiry
I've never changed a thermostat in my 3.4L and I would like some advice from people who have done it. In the repair manual that I have they make it sound so simple, but when I pop the hood there is a lot of "stuff" in the way. Or if you could direct me to a post that has already covered this. Any help would be most appreciated.
i replaces mine and it wasnt that hard i just used a socket wrench on the outside screw and a socket wrench with a swivel for the inside screw and it didnt take very long at all...
Its a really big ***** its a 10 mm if i can remember but the intake is soooo in the way on the right hand side. I just used a swivle socket and got that ***** out after a while. Its alot more easier after you done it a couple of times. but trust me the damn spark plugs are even *****ier especially on the passengers side
its really not as hard as people think. two bolts both of which i got off with a standard ratchet. i will try to post a pic later where the thermostat is located. and i would suggest flushin ur radiator with a hose while u have the thermostat out...really clean out ur engine then install the new one and fill er back up with some good quality coolant.
Standard socket with a 3" extention = Pissin in the wind
Pictures?? Where is the thermostat located?
OLD THREAD IS OLD!
Refer to a Haynes or Chiltons... I'm sure there's a picture in them somewhere. |
Thanks for the help.......I will just figure it out.....
hey i hope this helps i have a alldata cd i bought from autozone for the chevy camaro 3.4 v6 Vehicle » Engine, Cooling and Exhaust » Cooling System » Thermostat » Service and Repairhttp://www.alldatadiy.com/includes/i...note_blank.gif Notes Service and Repair Remove or Disconnect
http://www.alldatadiy.com/alldata/AF...6064/113242826
Thanks Tat, I have been working my days and sunlight away. Im probably going to check it on Sunday if im lucky.
| All times are GMT -5. The time now is 04:19 AM. |
