-   93-02 V6 Tech (https://camaroforums.com/forum/93-02-v6-tech-14/)
-   -   3.4 V6 Ground Wire (https://camaroforums.com/forum/93-02-v6-tech-14/3-4-v6-ground-wire-1325/)
vhodgesosu Sep 12, 2005 09:12 AM
3.4 V6 Ground Wire
This is my first post. I recently replaced my head gaskets on my 1995 3.4L Camaro and I have a ground wire that I have no idea where it goes. Some how i forgot to label it when I took it off. Anyways, I know that it bolts to the frame below the Air Intake and then bolts to the engine somewhere. It is a braided copper wire with a clamp attached to it. I think the clamp holds the wiring harness. I know it goes on the drivers side and somewhere on the lower half of the engine. If anyone could take a glance at their 3.4l and see if they could find out where it attaches that would be greatly appreciated.
Thanks.
85Camarodude Sep 12, 2005 08:08 PM
RE: 3.4 V6 Ground Wire
if nobody replies u can always go to a salvage yard and check one out there, might be easier if u can physically see the connection urself as well
z28pete Sep 12, 2005 10:14 PM
Connect it to any convenient spot on the engine block, just make it good an tight. It really does not matter where on the engine it is connected.
vhodgesosu Sep 13, 2005 02:17 AM
I guess that is what I am going to have to do. I just don't know what the purpose of the wire is. I will give it a try, it is better than not having it on at all.
z28pete Sep 13, 2005 09:51 AM
The purpose of the wire is to provide a good electrical connection between the engine and the rest of the car. The battery negative connects to the engine and has to be carried to the rest of the car in order for lights, radio, etc.. to work properly.
