3.4 upper engine swap
Old Feb 9, 2011 | 09:43 PM
Thunder66's Avatar
good point allright thank you ill check it out
Old Feb 9, 2011 | 10:25 PM
BasicConcepts's Avatar
Technical User
if you want to do a top end swap youll wanna go with the 3.5 top you need 3.1 pushrods and everything else will be 3.4 pm me if you have any questions i did tons of research on the subject
Old Feb 9, 2011 | 11:08 PM
Massey's Avatar
BC... Any luck on getting a new Camaro?
Massey
Old Feb 9, 2011 | 11:23 PM
WIspartan1026's Avatar
May 2013 ROTM
As did I. He actually used my thread for part of his research. He's trying to take credit for MY footwork
You'll probably want 3500 heads. 3400 heads will give you much higher compression, so your car won't run right on anything less than race gas iirc. The compression you get with 3500 heads will still keep you in the pump gas territory. Also, compression from 3500 heads will allow you to keep your stock bottom end. Otherwise you're going to need different con rods and pistons (3400 I think). Lower intake manifold can come from a 3400 or 3500 I believe, but you will have to cut a little bit of a notch in the housing to clear the timing cover. A 3500 upper intake manifold will NOT work. It won't fit under the cowl of your car. You will need a 3400 intake manifold, and even then you will have to grind the numbers off of it in order to make it fit. (idk how you remedy the throttle body situation, I never got that far). 3100 pushrods will do the trick. You will also need a new cam and one heck of a tune.
:catchesbreath:
The guys on fullthrottlev6.com answer these questions every day, and they know much more about the project than I do. It would be well worth your time to do some digging over there.
JoeR
Jun 13, 2013 12:57 AM
3800_seriesII
Aug 14, 2012 07:24 AM
BasicConcepts
Feb 8, 2011 08:35 PM
hpcamaro
Jun 27, 2008 03:48 PM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
