3.4 Upgrading
Old Feb 18, 2008 | 09:38 PM
3.4CamaroCDOG's Avatar
Default 3.4 Upgrading
ok so since my parents wont let me get a new car i wanna upgrade my 3.4
can i put a z28 camshaft in it?
the lifters and heads are new so i just need the camshaft
where can i get good lower rearend gears from?
does a 3400 impala engine bolt up to my trasmission? because if so i could take it to a engine place and just get a newer impala 3400 engine
Old Feb 19, 2008 | 06:22 AM
02StanGT's Avatar
Default RE: 3.4 Upgrading
Z28 cam - No. It has sixteen lobes whereas yours has twelve. Not to mention it's for a V8.
Rear gears - Any performance website
3400 engine - won't bolt up I believe, but I was thinking you could swap out the top end on them with yours. Look up "3.4 camaro top end swap", and you'll see some things. It entails heads and intake manifold.
Old Feb 19, 2008 | 11:13 AM
As Loren said, the transverse engines used in front drive cars do not have mounting provisions for installing them in rear drive cars. You can use the top(heads & intake)of the transverse engine but not the block or camshaft.
Old Feb 19, 2008 | 12:31 PM
aw so like a 2002 impala 3400 heads and intake would work?
Old Feb 19, 2008 | 07:15 PM
The will bolt on, but there is a wholu bunce of work and tuning to be done to make it run properly.
Old Feb 19, 2008 | 10:56 PM
aw so i could go to a place with a dyno to tune it? or a scanner or sumthin?
Old Feb 20, 2008 | 06:40 AM
02StanGT's Avatar
Yes, I would have it dyno-tuned. While mail order tunes are good, it's best to have someone who is seeing how your car runs, to tune it. If I remember right, swapping out the heads and manifold is going to raise the compression ratio, hence the need for tuning.
96ZLT1
LS Series Tech
11
Feb 9, 2011 01:25 PM
KillNThrill24
Nov 14, 2010 02:58 AM
HeeptoJeep
67-69 V8 Tech
Jun 5, 2009 09:18 PM
Awesome_Albert
Jun 14, 2008 12:54 AM
bigpapa0987
82-92 V8 Tech
12
Dec 10, 2005 02:05 PM
