3.4 throttle body to an aftermarket one, maybe???
Old Dec 25, 2006 | 08:05 PM
Raidenvaga's Avatar
Default 3.4 throttle body to an aftermarket one, maybe???
I'm curious has anyone tried or attempted to replace the stock throttle bodyto aftermarket one ??? I was thinking to try it and see the effect of an double barrel 58mm bbk can do for me, if I can get it to fit in.. Well I'm going to figure it sooner or later, LOL... Well anyone with answer, please help me out...
Old Dec 26, 2006 | 07:08 PM
Default RE: 3.4 throttle body to an aftermarket one, maybe???
You can use the TB from a chevy 4.3. It is huge and can be made to fit with a little work. Aside from that, it is a waste of time and money uless your engine is heavily modified and needs more air than the stock TB provides.
Old Dec 27, 2006 | 12:41 AM
Raidenvaga's Avatar
Yea, it an waste of time... but while I have time to build it up for racing at kil-kare , ( thats ohio track )... Can't have an 3.4 v6 camaro look bad at the track..
Other camaro might throw stuff at me and boo me off the track , LOL..
Summer time it should be ready...
Thinking that now that I'm single again,lol
deciding on 2000 Trans-am or 2000 vette.. but I'm keeping the v6 camaro.. I was going to sell it but I change my mind
Old Dec 27, 2006 | 04:05 AM
AlfredB18's Avatar
As badly as the heads and intake flow on the 3.4L, the 50MM TB is way more than adequate for the job.
Of course, if you just have not mentioned your aluminum heads/intake swap yet, then the stock TB may not be enough in that case. I think an LT1 TB unit can be made to fit in that case.
Old Dec 27, 2006 | 05:25 AM
Raidenvaga's Avatar
most of all mods are from ftpp.net ( Full throttle ) check those 3.4 dome piston & 52mm holley
Old Dec 29, 2006 | 04:22 PM
sooperdewd's Avatar
Well I was looking into it, and for the 3.8's I found Edelbrock's You'll need a new Carb, but they claim the stock 200hp increase to about 260hp.
B_Dubya
Sep 23, 2014 11:01 AM
peter_x
Jul 11, 2013 07:52 PM
Stix80
Jun 2, 2011 10:26 PM
Envisi0n91
Jan 25, 2010 07:47 AM
Z28man
Apr 30, 2006 12:42 PM
