3.4 Intake Manifolds And Turbos
Old Oct 11, 2006 | 07:28 PM
94CamaroSFI's Avatar
Default RE: 3.4 Intake Manifolds And Turbos
I just got a quote on swapping upper/lower intake pelenum, heads for $800. Changing pistons adds up to another 250 bucks from a local shop
Old Oct 12, 2006 | 12:10 AM
2fast4u's Avatar
so maybe 1250 for heads manifolds and pistons is that all i would need to do wat about a new cam
Old Oct 12, 2006 | 02:01 AM
V6PoWeR's Avatar
I dont remember exactly, but I'm pretty sure you will need a new camshaft, flat tappet it what was best, i think, but it'd be wise to do some looking around
Old Oct 12, 2006 | 10:30 AM
Dude I've already done all the scouting on cams.... Check out my other post
I called Crane Today and gave them all the information about my car 94 3.4 v6 all that, and he suggested this cam POWERMAX 2030. what concerns me is the fact that it says it is made for 2.8-3.1L from 1980-1996. Will this cam work? I would imagine it would sense theoretically the 3.4 is basically a 3.1 stroked. $209.00
Here's the Links....
POWERMAX 2030 RPM Range:1200-4600
http://www.cranecams.com/index.php?s...22&lvl=2&prt=5
UPDATE: Talked to SUMMIT and they advised me to go for Crane Compucam and Lifter Package for 169.00 RPM RANGE:1,500-4,500
http://store.summitracing.com/partde...2D254122&N=700 4294908216 4294840048 4294819990 4294925232 4294924497 115&autoview=sku
Talked to SUMMIT again and was advised to go for the COMP CAMS HIGH ENERGY w/ Lifters for $204.00 Due to the fact that the rpm range is from 1,000 -5,000 RPM
http://store.summitracing.com/partde...D233%2D4&N=700 4294908216 4294840048 4294819990 4294925232 115&autoview=sku
I think Im going for the COMP CAMS HIGH ENERGY It's hydraulic flat tappet 1,000-5,000 RPM
Old Oct 12, 2006 | 04:11 PM
Bubonic's Avatar
You will also want custom push rods from what I have read so things wear better and I am guessing it would run a little better too.
But you also have to have headers for this to work. The manifolds dont just bolt up.
You will also want to you dont have to but you will run rich without a pcm tune. You ecu thinks you still have 55cc chamber and you dont. So you will want to balance it all out or you wont get as much hp as you should.
Old Oct 13, 2006 | 12:23 AM
2fast4u's Avatar
is there any site or anything i can go to that will have a full list of everything i should do for the swap and parts list or anything like that if so let me know thanks oh and this is all the same for the firebird cause thats wat i have just making sure.
Old Oct 13, 2006 | 11:21 AM
Yeah As long as it's a 3.4L Firebird.
Old Oct 14, 2006 | 02:26 AM
2fast4u's Avatar
ya its a 3.4L so is there a like total list of everything i need to do on the wb somewhere
Old Jan 16, 2023 | 12:47 AM
minkey's Avatar
Default Why is 13:1 bad ?
That is extremely high compression. You dont want to run that high. Changing pistons is the best way.
The reason why its so high is the Iron heads have a compression chamber of 55cc and the alu heads have a chamber of only 28cc something like that. But thats a big difference
Old Jan 17, 2023 | 06:14 AM
  #20
Keep an eye out, this is a 18 year old post. Are you aware of anyone that has done this? I have not followed the 3.4's in a long time but in the past all I have seen was theoretical builds. I know of one case where the guy started the build and the thread ended when he was about 75% finished. I assumed no one wanted to figure it out at this point because the LT1's are dirt cheap.
I am not real interested in the 3.4 for the camaro because of its weight and size but a 250 hp Fiero sounds like fun.
MrBlah
Sep 29, 2011 04:01 PM
resurrect
Apr 20, 2011 02:08 AM
SSPOWER
Mar 7, 2008 05:41 PM
95z281LE
Jan 5, 2008 11:15 AM
2fast4u
Oct 5, 2006 01:09 AM
