3.4 camaro build
hey im new here and need some help. i just blew the motor in my 94 camaro ive built tons of motors but all 350s and 383s. i wanna keep the 3.4 and build it heads cam and eveything.. i want to go as far as it will go. and get the most hp out of a v6 with boost but i wanna boost it later on... does any one know of a good site to get parts for this motor i cant find one?? thanks
For getting the parts you may try giving PAW a call. Also there is a link around here for rebuilding the 3.8L, the place that built that engine can prolly give you tips and places for parts to your engine. The porting of the heads and intake should be about the same technique on both engines (it is the same as a V8 porting). I will try to find the link again and post it here for you.
Massey |
ive been told that the heads off the 3.5 FWD out of a Malibu work good on the 3.4 as for boost are you talking turbo if so ive also been told that this motor wont hold a turbo the 3.4 is the worst engine GM ever made you cant forget that swapping to a 3.8 will allow you more mods but isnt an easy job
thanks massey yeah ill look in to porting the heads.. and i wanna buid a 3.8 later and but it super chargerd no one in my area has a 3.8 will a 3.8 bolt to my stock 3.4 tranny??
with 3500 V6 heads and lower intake manifold, 3400 V6 upper intake manifold, 3.1 V6 pushrods, cam, and a tune, you can get around 230 hp from the 3.4L. I was going to do this to mine, so I did a lot of research (but then I got an LT1 haha). fullthrottlev6.com would be a good resource for you.
idk about your trans question, but I kinda doubt it. Don't take my word for it though. |
just called my auto guru he said but isnt 100% sure that the trans wont bolt up but bell housing off the 3.8 will bolt to the 3.4 tranny
3.4 are in no way shape or form interchangable with a 3.8. You would need a donor car for the swap just like a V8 plus all the computer issues that come with a OBDII motor in a OBD1 car. Your best bet to to research what WIspartan posted. The factory cast iron 3.4 heads are very limited. Even with the max port and polish you will not get the flow of a 2000 3.4 set of head off a FWD. The 3.5 FWD are a notch better then the 3.4 FWD.
wow thanks so im gonna get 3.5 heads and a cam for now when i come along a 3.8 i wanna build it supercharged. ive seen some sick 3.8 cars.. ill post pics of my build.
if you have questions feel free to ask me. I did a lot of research on this stuff, so I can answer most of your questions or at least show you where you can find answers.
Originally Posted by ghostrider
(Post 430031)
Massey |
