-   93-02 V6 Tech (https://camaroforums.com/forum/93-02-v6-tech-14/)
-   -   2000 not firing, no spark (https://camaroforums.com/forum/93-02-v6-tech-14/2000-not-firing-no-spark-62248/)
texas_RS May 31, 2011 08:01 AM
im stumped... 2000 fuel pump kicks on so it cant be the VATS. ignition module, coils, wires, plugs, crank position sensor, and cam position sensor are all brand new... it turns over fine, it just wont crank up. any ideas on what it can be??? any and all help is greatly apreciated :icon_doh:
Massey May 31, 2011 11:28 AM
you tested spark? or just replaced all the components?
have you tested the injectors for firing with a noid light?
Any codes?
what is your fuel pressure readings at?
Massey
texas_RS May 31, 2011 05:37 PM
tested the spark, nothing... injectors are good, no codes, and fp is like 41 psi... its getting power to the coils, its just not making sparks
