1995 Camaro V6 3.4 runs like crap
Old Jun 17, 2012 | 09:49 PM
1995camaro**'s Avatar
would disableing the abs by removing the fuses and relay cause my problem? i just thought of this.. thanks ahead of time for your input!!
Old Jun 20, 2012 | 01:43 PM
vanquishfist's Avatar
I wouldn't think the ABS would do anything. Has the fuel pressure been tested? Any coolant in the oil? 3.4's are prone to head gasket failure.
Old Jun 21, 2012 | 09:47 PM
good pressure and no white smoke or coolant in the oil or vise versa. idfk whts goin on i gave up i dont have time to **** with it lol its sceduled to get fixed monday so ill find out soon! lol
Old Jun 25, 2012 | 07:57 PM
well i checked everything over to find out i have a dead cylender... freakin awsome... trying to figure out what i want to do with it now... idk if putting a used motor in now would b cheaper than having the one i have now fixed.
Old Jun 25, 2012 | 08:55 PM
dead cylinder becuase what? if no coolant got in oil then it may be cheaper to fix the motor you have, depends on what it is.
Old Jun 27, 2012 | 06:15 PM
low compression in cylender one so its either a head issue or a ring issue
im feelin a lt1 swap!
Old Jun 27, 2012 | 09:22 PM
pull the heads off and see if head gasket is bad. lt1 swap is not an easy thing to do. need a doner car.
Old Jun 28, 2012 | 06:55 PM
ik its alot of work but i think its worth it. ill prolly do that in the mean time while im looking for a wrecked v8 car id feel bad tearing down a nice one
Old Oct 10, 2012 | 01:40 PM
so i pulled the whole top end off n ill b honeset im a little confused... the gaskets all look fine... but the kicker is the exhaust valve on my dead cylinder is coated thickly with carbon build up... so i was thinking it was maybe a bad valve seat so i tipped my head so the combustion chamber was facing up n i filled it full of penetrating oil to see if it would leak out of my valve seats but nothing leaked... so idk what could b causing that build up and low compression in that cylinder... any ideas?
Old Oct 10, 2012 | 03:21 PM
  #20
did you look over the intake gaskets to see if there was a leak there
