1995 Camaro V6 3.4 runs like crap
Old Apr 17, 2012 | 01:22 PM
1995camaro**'s Avatar
Default 1995 Camaro V6 3.4 runs like crap
So i am new to this so i am sorry if i am doing this wrong lol but i have a camaro with the 3.4 v6 in it. it runs like crap. it seems like its constantly misfiring all the time especially under a load. i changed plugs and wires 3 times, bought a new used computer for the engine, and checked my coil packs and still nothing. i took it to a shop near me to see if they could read any codes and they told me somethings messed up cuz they could unplug what ever they wanted and could not throw a code... and they cant read any of the live data either... so im to the point where idk what is wrong and i need help bad!
Old Apr 17, 2012 | 02:53 PM
libertyforall1776's Avatar
Buy your own OBD-I compatible scanner and check the codes yourself, Autoxray EZ-Scan 6000 is one...
Old Apr 17, 2012 | 04:40 PM
c thts the thing i borrowed my schools and still nothing i cant even read to see what the live feed data is like the rpms or throttle percentage or anything... idk if its a bad ground issue or what the deal is... this weekend i was planning on checking all my grounds i hope its something easy at this point...
Thanks in advance!
Old Apr 17, 2012 | 05:59 PM
also it seems to run really rich and theres alot of fumes that comes out of the exauhst with black crap too....i just cant figure it out n its frustrating the crap out of me... any ideas would be extremely helpfull!
Old Apr 17, 2012 | 11:41 PM
bennygunns's Avatar
Here is a good post that would be a good starting point: https://camaroforums.com/forum/repai...hooting-41933/
You might have a blown gasket if you have a lot of black smoke.
Old Apr 18, 2012 | 09:29 AM
thanks ill take a look at this and piddle with my camaro over the weekend to see where it gets me... and i could live with a gasket thts pretty easy fix!
Thanks!
Old Apr 18, 2012 | 09:38 AM
but that thread still doesnt explain why i cant throw a code at all even if the motor is running and i start unplugging things... to me that doesnt make any sence at all only thing i could think of was a bad ground or a wire that got snagged from when my brother totaled it. because ever since then its ran like a$$ . so i think this weekend ill start by checking all my grounds and connections then checking for bad wires then onto to see if i have an intake gasket leak which rite now im kind of doubting.. but well see!
Thanks Guys!
Old May 15, 2012 | 06:30 PM
well i checked all my grounds and they seem fine... i even tried running a ground wire from the frame to the motor and that didnt help so idk what is going on... so im to the point where when i get some money built up im taking it in for someone else to deal with lol unless i think of something else that could potentially wrong lol
Old May 15, 2012 | 08:47 PM
There is a good possibility that the scanner being used is not what the car needs. The PCM in your car is OBDI but the connector is OBDII. Many shops are not aware of this and will hook up a OBDII scanner just because the cable on the scanner connects to the test port on the car. If this is what happened, then the OBDII scanner won't be able to talk to the PCM and pull the codes. You need a OBDI scanner with a cable that has a OBDII plug.
Also check the fuse for the cig lighter, as it also provides power to the test port.
Old May 16, 2012 | 07:32 AM
thanks that makes sense ill try that once! maybe then it can give me a code so ik where to start... thanks!
