1995 3.8 v6 camaro
Top or bottom either works for this engine if you remove the heat shields from the manifolds first. Once the heat shields are off it is pretty easy to get to the plugs. From the top it is mostly by feel from the bottom you can usually see what you need.
Massey
Massey
