1993 V6 Camaro
I just purchased a 93 3.4 Camaro.. Looking to do an engine swap and some work to it .. What motor would you go with for alot of power and would be the simplest to install. What other upgrades would you recommend for motor,appearance,sound etc.
RE: 1993 V6 Camaro
well, when working with a 4th gen you should know that no matter what, doing an engine swap is a lot of work and not simple at all, the parts that are on a V8 body are very different, so youd spend more swapping than to buy a LT1 V8 camaro, and start from there.
by the way there is at least a thousand people that ask that same question, so you should look through the threads before asking this. |
