1993 Camaro RS 3.4SFI starting problem
ok guys, I have a 93 Camaro v6...I changed a fuel injector a few weeks ago n out of stupidity..i also changed the Plenum Gasket (air intake gasket) and now it did run for a lil bit after I changed everything but idled horribly though..then one day I had to move it n then 3 days later it wouldn't start at all. so for thre last month...it has done nothing but crank and crank but will not start...I really need help guys...please and thank you P.S. heres my video of what it does now..........
Being it idled crappy right after you did the work, you need to trace your steps.
Are you sure you got the gasket surfaces perfectly clean? If a chunk of old gasket was left behind, it can give you a gasket leak.
What kind of injector did you put in? If you're only changing one, you want to stick with an OEM brand, or you could end up with
uneven flow rate issues between cylinders (been there, did that...oops you learn).
I did check the gasket...everything was clean and all the vacuum hoses were back on nd everything...u think maybe if i put my old injector back in it..itll run or am i juss screwed...n yes has fuel n spark
What was wrong with the old injector? Swapping the old one back in will help to determine whether or not the new injector is the culprit. I fought this issue once, with a clogged injector, and a couple tanks with Lucas injector cleaner did absolutely squat btw. So I replaced it with an aftermarket injector, and the engine ran even worse. So I soaked the old one in carb cleaner for a while, gave it some periodic swishes, and it ran like a charm.
If the car has fuel, air, spark and compression it will normally do something, Backfire try to catch something. How do you know it is getting fuel and spark?
On a side note, the car does not sound right when it is cranking. Kind like only 2 or 3 cylinders have compression. Maybe its just a video thing?
Well I changed it because my old injector was leaking n gas smell wax strong n stuff ...n oh the new injector I bought was from AutoZone...maybe a autocraft or somethings......n fuel pressures Ichecked by primer n checked plugs for spark
