Transmission question just wondering
Old May 2, 2012 | 03:09 PM
dn1186's Avatar
Default Transmission question just wondering
Will a 95 tranny work in a 94 car both z28s both 4l60e's I know the 95 has a pwm and I know you cant put a 94 into a 95 because of that reason but can you put a 95 into a 94? Thanks
Old May 7, 2012 | 08:29 AM
both should be 4l60e, only thing i can think of that may be different is the plugins so if you can check to see what shape and how many pins you have on the 94 and 95.
Old May 7, 2012 | 09:49 AM
BasicConcepts's Avatar
Technical User
ohh no i went through this same issue with my 94 and the answer is no only a 94 trans will work the 95 will not lock up and youll burn the clutches up real quick but if all you can get is a 95 trans you can get the trans go hd2 reprogramming kit its basically designed so you can run a 95 trans in a 94 it costs about 70$ and took me about 1.5 hrs to install
TransGo Performance 4L60E-HD2 - TransGo Performance Shift Kits - Overview - SummitRacing.com
if you do decide to go this route shoot me a pm and ill give you all the info i know on the install
RS1992
Apr 18, 2015 09:29 PM
superhotchevy
Sep 2, 2011 09:49 PM
Avizion
Jan 29, 2007 11:10 PM
bjames5
Jan 22, 2006 04:15 PM
