tranny i.d confirmation needed
i always thought that all 93 Z28's came with the 4L60 trans, untill i decoded my S.P.I.D and came across RPO code MD8 which states THM 700R-4 trans
can anybody confirm this thanks Brad |
700r4 is the same trans as a 4l60. gm just changed the name, 93 has a unique trans, not in any other camaro. has a round 5 pin connector.
is the round connector for t.c or v.s.s cause i'm trying to find a v.s.s connector cause mine is toast
plus the p.o installed the tranny and i have no clue what it came out of |
the round one is for the tc the vss is on the tail housing.
if it has a round 5 pin plug then its a 92 vette or 93 camaro trans. here is a vss plug http://www.ebay.com/itm/93-LT1-Camar...ht_1911wt_1013
i haven't had a change to go underneath to check the t.c connector
is there anything i can do if the trans is not a round 5 pin connector |
a good trans shop can wire in a 5 pin plug if its set up to do it. i dont know what the difference is if any on the inside the trans. the 93 locks the tc in 3rd gear, something i dont think the older ones can do.
bout ready to yank the thing out and go with a th400
i love trying to straighten up other peoples messes |
instead of changing trannys or having this one modified couldn't i just get an aftermark lock up kit from TCI or something like that
400 install would cost as much as a built 4l60. have a look at what patc has. building a trans is not easy. i wont do it.
