Rear End Problem
Old Aug 30, 2011 | 05:49 PM
bball1621's Avatar
Default Rear End Problem
I just replaced the rear end on my 93 camaro z28 with a 5.7 lt1. i have new richmond gears and a carrier. all bearings are brand new and everything. i have the back lash to .004 the pattern is perfect on it. i have done alot of rear ends and this one just gets me. when going down the road it howls really bad. i know all the bears are good i didnt over tighten anything. i can tfigure out why this rear end is making so much noise. i am debating on maybe trying to put thicker oil in it to see if that helps. but this is the second set of gears put in this. the first one did the same thing and i sent them back and got a different set to see if maybe they were machined wrong. the rear end is a 3.73 with a 8 and 1/4 carrier. can anyone help me figure this out.
thanks.
Old Aug 30, 2011 | 05:58 PM
Richmond gears are known to be noisy, more so than other brands. Do a "Richmond Gear noise" google search, and read away.
Old Sep 1, 2011 | 10:14 AM
bball1621's Avatar
alright i have to do some checking around. i have a feeling my rear end housing is bent some how. i don tknow how it would be bent but im gonna keep doing some research. thanks for the reply though.
Old Sep 1, 2011 | 10:22 AM
mine has richmond gears and is very loud. i think the center section is toast as well cause it vibrates when i get over 70. oh,,,,ummmm,,,, not to say i drive over 70.
Old Sep 1, 2011 | 10:31 AM
bball1621's Avatar
lol. have you checked your u-joints that could be causing vibrations. i can go fast with my car and no vibration but the whinning is so high pitch i can barely hear it. but when i get to 45-60 mph it whines. i did some research and alot of people are saying to use lucas gear lube. it aparently sticks to the gears and it will quiet them down alot or completely.
Old Sep 1, 2011 | 10:39 AM
yep new ujoints and driveshaft. only thing in the drive train not replaced with the motor is the center section and the axles and axle bearings.
Old Sep 1, 2011 | 02:33 PM
bball1621's Avatar
well i kinda doubt it is a bearing but possible. i would have to say something is wrong with your rear end then.
Old Sep 1, 2011 | 03:01 PM
Psycho's Avatar
how did you arrive at .004 for your backlash? According to their website the bl is marked on each gearset, as they are pre-run at the factory.
Old Sep 2, 2011 | 09:00 AM
bball1621's Avatar
i have all aftermarket gears. i had to set it all up. new richmond wasnt factory.
Old Jan 26, 2012 | 05:50 PM
kulungi63's Avatar
I have a 1992 Camaro RS with only 39K and have the same problem the backed makes a nasty sound. It does it at all speeds just changes pitch and loadness. I have not changed anything yet but dont want to spend allot of money before I know what the problem is. I think its the passager side outer axle bearing thats wear the sound is coming from. I need help to resolve the issue. Thanks
