more trans woes
i got the trans back in it, only got 2nd and 3rd gear now. And i have to shift it manually, plus its a ***** to get into park and none of the gears are in the right spot. I think i may have bent the shift cable bracket. but even then, it should dtill have all gears once it is actually in drive... Im smelling a 5 speed swap
