lets hope this is the right one
4l60e rebuilt 8 months ago12,000miles trade 700r4
he says its from a 94 1500 V8 2WD if its right it will be worth the trip to atlanta
need to check plugins, overall length, mount position, spline count ummm thats all i can think of. make sure they all match up. if the same length and shaft matches you should be able to exchange the rear housing if the mount is different. try callin a wrecking yard to see if they have a cross reference for what trans will fit.
the only difference case wise is the tail shaft housing which is changeable (the torque arm mounts to that on the camaros only) as for the spline im pretty sure there all the same...
but the bad news is its not the right trans the wiring is different so it must be a 95+
