fine tuning ones shift points
Old Dec 31, 2010 | 07:44 PM
H2C's Avatar
H2C
Originally Posted by Massey
The main question is how much are you going to change it? The stock for your car was 3.08 which is a good cruising gear. If you want to shoot out of the hole faster and get a little better time in the 1320 then you need to get somewhere in the 4.xx range to notice a performance and mileage change. Yes with an extreme change you will notice a drop in mileage. Remember that you will NEED to have your computer adjusted to the new gear ratio. This may be why you were advised that it is not worth the effort. The computer knowing the ratio is important with the trans shifting, ABS, and speedo readings. It can also play into your fuel mapping and cause driveability issues like DarlingReject discovered with her car.
Massey
Caught my attention here, what kind of issues are we talking
Old Dec 31, 2010 | 10:51 PM
Massey's Avatar
DR was having problems with her car not running as well as it did with the factory settings and also the shift points were not where they should have been. Your computer gets its speed readings from the trans speed sensor tell the computer how fast the car is going. This plays into fuel mapping (by comparing data from the MAP and MAF for engine load) shift points (again with engine load data) ABS sensor comparison to vehicle speed) Airbag deployment data (on some systems I am not sure about the Camaros of our years). All these and prolly more are reliant on semi accurate data from the speed sensor. a MPH here or there is not going to matter much but 10 MPH or so will matter alot.
Massey
Old Jan 1, 2011 | 01:05 PM
H2C's Avatar
H2C
Default fine tuning ones shift points
Massey
Is there a quick way to remove the factory top speed limiter, like a chip i can pull. And how would one go about fine tuning ones shift points on a 97 4l60e?
Old Jan 1, 2011 | 05:22 PM
Massey's Avatar
That is all done via the computer, You need to have a tranny shop or dyno shop reprogram the shift points and shift conditions.
Massey
Old Jan 1, 2011 | 05:48 PM
H2C's Avatar
H2C
Massey
Well i was wondering if there was something i could get so i could take to the street peg it and set it for how i feel is right
Old Jan 1, 2011 | 09:49 PM
hows that. work for you?
Old Jan 2, 2011 | 08:17 PM
H2C's Avatar
H2C
Im so confused, did i break time space?
anthony7888
70-81 V8 Tech
May 27, 2012 12:45 AM
1974z28
May 4, 2010 11:16 PM
ashmason
82-92 V6 Tech
Dec 16, 2008 02:03 AM
02renegade
May 7, 2006 09:18 PM
