96 4l60e issues
Hey all,
I have a 1996 Base Convertible with the 3800 v6, 4l60e automatic I have a few questions to hopefully figure out if my transmission is having issues due to a PCM issue or a true tranny fault. Let me run down the scenario that led to this:
I have also read the service manual, and see that these two causes are the same between my main two problems: Spacer plate or gaskets incorrect, mispositioned or damaged. Turbine shaft seals missing, cut .or damaged. Any easy way to test these without pulling the tranny? I live in an apartment complex so the less I have to remove from the car, the better. I am still willing to drop the trans myself though. Thank you all in advance. |
trans is toast
Clutches are now shot, You had low line pressure to start with, and that can be caused by something minor or major, but now the clutches are shot, Time for a rebuild and with the age you are talking a full master kit+ anything else they find. If you drop the pan you will see black soot in the fluid, that's your clutches
Thank you gorn and craby. You guys are literally legends on this site. I know that the only years I can take a trans from without any changes would be a 96 or 97. What would I need to do to fit a 95 or 98 4L60E? The local yard has tested trannys for around $200 (if you know a guy) but the only 4th gens they have are those two years. |
not up on trans, I would think the 3.8 auto trans would be same 96 up but plugins for computer must be different. maybe call a trans shop and see if they will talk with you about it.
From what I found the 95 is different electronically and the 98 is physically different. 96, 97 are your only direct bolt in options. Now if you feel brave you take the insides from the 98 and put them in the 96 but there are a lot of things that can go wrong. All my Camaros are sticks :) so I have no first hand knowledge.
http://car-part.com/ |
Gorn and Craby, thank you again. My last question seems pretty obvious given that the Firebird and Camaro are pretty much the same vehicle, but if I found a 96 or 97 firebird trans in the yard, would that be good? |
Sure,If you pick on the above link and search for your car and parts. In the listing of the direct fit parts it will show you the car and year it would be coming off of. I use in the reverse to see was compatible. In your case 96-97 firebirds do show up on the list, but there are no 95s or 98s do.
Thank you Gorn! That link should be in a sticky somewhere 🤔 |
