LiveIt! |
06-12-2018 10:18 PM |
2000 3800- Random rattling & smoke from transmission area
Hey guys, still fighting the 2000. No more misfiring, but fuel pressure issues now. After an un-needed fuel pump change, the car's acting strange. To get the pump out I had to raise and drop the rear axle, I'm guessing this is where something went wrong. When I first drove the car there was noticeable smoke from around the O2 sensor after the exhaust heated up, I blamed it on all the rust penetrate I had sprayed on. But now there's smoke from the engine bay when you lift the hood, and there's been evidence of something leaking on the exhaust pipe that runs under the rear of the engine. I guess it's finally gotten worse. I put a new tranny mount on because that's what the rattling sounded like, but you can still hear it when accelerating and cornering at the same time. Tranny fluid looks fine, oil looked....ok, maybe a little runny. Don't like how easily it dripped off the dipstick. Could I have blown a seal or gasket when I had to lift and drop the rear axle? I'm at a total loss here guys, many thanks for any input....
