EOWS 612 |
06-02-2012 11:24 PM |
1998 Camaro 4L60E slips in only in 1st
I have a 1998 Camaro with a 4L60E and the limted slip differential with 178000 miles on the odometer. At first it didn't want to shift up out of 1st gear from a complete stop and now it has started slip in 1st as well. If I let out of the gas for a second it shifts up and then it shifts fine. Also in reverse the rear end makes a popping sound for about 5 seconds then it goes away. None of the warning lights have come on either. The only work that the previous owner had done to the car was a new differential about 10 years ago. Any help, ideas, or suggestions would be appreciated, thanks!
