Would Koni adjustables and Eibach Springs fit a 4th gen camaro?
Would that be a good shock and spring combo?
RE: Would Koni adjustables and Eibach Springs fit a 4th gen camaro?
you will love the Konis:) but if you want to be able to use them to their fullest (which might actuallybe too much for the street) you might want to talk to their tech dept and see what the consider a nice balanced spring for the struts/shocks.
that is a very common overlooked problem with suspension upgrades. people upgrade their springs and leave stock shocks in and by doing that, they are leaving out so much of the added benefit they should be enjoying |
Yea i bought eibach springs and kyb agx front stuts... stock rear shocks! i also have a 32mm sway bar and strut bar up front. But the rear is just lagging behind so bad with the stock shocks. I would say koni or kyb agx adj. But my eibach pro kit springs seem to be doing just fine. most places the springs will be around $250. Think about sway bars, control arms, strut bar, panhard rod. MOST IMPORTANT!!! do a suspension bushing upgrade too. All of that wont do **** if they dont have a nice solid base.
ORIGINAL: CamaroKid16 MOST IMPORTANT!!! do a suspension bushing upgrade too. All of that wont do **** if they dont have a nice solid base. |
i've been learning alot form you ss!
Hey I learn a lot from all u guys and I thank all u guys.
I cant wait to order all my new suspension and throw it on.. In my opinion, my favorite part about driving is being able to take corners with precision and speed, while scaring the daylights out of the person in the passenger seat! ;)
