shock for weight in rear
Old Jul 16, 2013 | 11:47 AM
Chevra's Avatar
Default shock for weight in rear
I have an 02 ss and the rear end sags a slight bit, this could be due to my sub box and two 12“ subs and amp. The car only has 68k kilometers on it but what shock or spring could i use to compensate for my extra weight back there? Will bilsteins do the job? I know that most people go with the lowering spring and shock combo but i do not want to lower the car at all, if anything i want it higher ha. With my longtubes i have enough clearance problems driving in this area as it is. Any suggestions would be greatly appreciated. Thanks!
Old Jul 16, 2013 | 12:15 PM
Cheeks's Avatar
August 2011 ROTM
do you still have the spring isolators in the back? If not, that can give you an extra inch or so and really make the *** end stand up
Old Jul 16, 2013 | 01:32 PM
Shocks have nothing to do with the ride height. Your car has saggy spring-itis.
Old Jul 16, 2013 | 01:57 PM
Chevra's Avatar
I have no idea i will have to take a look, i have never touched the suspension since i got it. The rear shocks were replaced once by the previous owner. What are some spring suggestions then?
Old Jul 16, 2013 | 02:11 PM
Cheeks's Avatar
August 2011 ROTM
a set of stock springs/isolators would do you well to be honest, but check to see if you have them first
Old Jul 16, 2013 | 02:20 PM
These fit inside the coil springs and are an easy inexpensive way to level your car: Air Lift 1000
Old Jul 31, 2013 | 09:06 AM
Chevra's Avatar
Sorry I have been gone for a while but are the spring isolators on the bottom of the springs? I took a quick look under and didnt see anything but maybe I just dont know what they look like on these cars. Thanks!
Old Jul 31, 2013 | 11:03 PM
libertyforall1776's Avatar
What Camaro 69 said, plus if you have stocker orange de Carbon/Delphi shocks -- replace them as well for better damping. Be sure to check your bumpstops as well.
As I recall, the rear spring isolators are above. You might find this interesting, but you will want a stock unit which will be thicker:
Custom Made VT rear Spring seat isolators !! Any Interest??? - LS1TECH
Old Aug 1, 2013 | 06:14 AM
what is the measurement from ground to the fender at the center of the wheels. front and back
Old Aug 1, 2013 | 05:45 PM
Chevra's Avatar
Okay I took measurements on all four corners and this is what I got.
Driver side: Front - 27 3/4
Rear - 27 1/2
Passenger side:Front - 27 1/2
Rear - 27 5/16
This is on 275/40R17 tires(which are pretty worn in the back and should be rotated right away I should add). But seems that my car also leans to one side, not sure what that is about either.
