Rear end shift with lowered springs?
Old 03-16-2018, 09:51 PM
Kingroach's Avatar
Default Rear end shift with lowered springs?
I keep seeing comments about needing to install an adjustable panhard if you get a lowering kit. Can anyone tell me why the rear end shifts when lowered?
Old 03-17-2018, 06:41 AM
the panhard bar keeps the rearend from moving side to side. the bar runs from one side to the other and is set to be centered at stock hight. as the car body moves up it moves from side to side. if you lower or raise body it will set one way or the other.
Old 03-17-2018, 08:38 AM
Kingroach's Avatar
Thanks for the info.
Maybe you could answer these questions also:
If I'm getting a 1.25" lowering kit do I need to get control arm relocation brackets? What size bump stops should I put on the rear?
Thanks
Old 03-17-2018, 11:58 AM
depends on the tires. if wide yes, i have 315s on the 93 and had to roll the fenderwells, also adjustable panhard. without i would have one side rub when hitting dips, worse if i had weight in the back. stock bumpstops should be ok. can always go back and change if needed.
Old 03-17-2018, 01:54 PM
Kingroach's Avatar
Thanks for your time and advice. I went ahead and ordered an adjustable bar just to be safe.
Old 03-17-2018, 03:01 PM
kool and they dont cost to much.
Krusher RS
05-23-2013 11:51 AM
DarkKnight
04-24-2010 12:56 PM
xCx777
12-01-2007 12:33 PM
buddywackos
05-02-2007 04:48 PM
badpig
01-04-2007 03:05 PM
Quick Reply: Rear end shift with lowered springs?
