Question on Koni Street8250-1005 install on 97
Need some confirmation. Installing Koni 8250-1005 streets front and rear on my wife's 97 camaro with std springs. The shocks arrived with no assembly sheet from BMR. The new Koni Shocks include two metal plates. The Large one is clearly for the lower spring and I assume i can reuse the spring insulator. Does anyone know if you re-use the lower spring insulator. I would also like to confirm the smaller plate goes on the upper strut rod over the bump stop before putting the black plastic rod protection. Looking for confirmation on the placement of the smaller plate and the re-use of the lower insulator.
https://cimg8.ibsrv.net/gimg/camarof...b68115b956.jpg Shows the lower spring insulator installed and the small metal cap on the bump stop |
see if this helps
Thanks Craby I
will move the small cap to the top of the cylinder below the bump stop. Another detailed very good thread is on the LS1 forum.https://ls1tech.com/forums/suspensio...-6-5-15-a.html |
| All times are GMT -5. The time now is 06:20 AM. |
