noise from rear
i'm hearing a "groaning" noise from the rear of my 98, especially when i back out of the driveway (slight drop-off at the end) . not squeaking, lower pitched. had bushings on sway bar replaced by dealer, still does it. anyone else heard same?
RE: noise from rear
Did you have the brakes checked (dragging caliper, no biggie) and the shocks? Could be a lot of other things though. If it only does it then and no other time I'd just watch it and do nothing.
RE: noise from rear
Prob trans or rear end related man, suspension wont usually groan
RE: noise from rear
replaced rotors and pads, noise is 90% gone. think new shocks will help with the rest.
RE: noise from rear
Control arm bushings or sway bar bushings. they will groan when they get old and dried out. Mine did.
RE: noise from rear
well could be the emerg brake. Or could be the back brakes that need changing. Rear brakes have lil metal things that let u know that the rear brakes are needed to be changeed.
RE: noise from rear
check the shocks
