My 95 camaro doesn`t sit level
Hello all,My 95 v6 camaro leans tward the passenger side.
Just bought the car---guess the passenger was big! So I put a new interior from a parts car. I need to change the springs,shox and struts. While I`m at it--I wanted top improve the suspension---stiffin it up bigtime. Does anyone have any links where I could get performance springs ,struts and shox. Any tips on what to go with will help as well. thanx all dvader Edit6.18 pm----found some stuff http://store.summitracing.com/egnsea...115+4294841605 |
RE: My 95 camaro doesn`t sit level
I can tell you what combination and parts to use, but the places to buy them are spread. Just look down below here, and taht all my suspension parts. I haven't done the rear end but using kyb agx shocks in the raer, panhard bar, control arms, and a rear sway bar. And some polyurethane bushing. You'll be good to go!!!
listen to the kid there;)
There is a reason why your car isnt level..Possibly broken spring, worn bushings,bent control arm. Make sure you have all the same size tires.
