Ugly rear saggy look...
Need to determine what is causing the sag first. Blown out shocks? Worn out springs? Then replace them
Also, most of the 4th gens have a spring isolator, a rubber spacer at the top of the spring. Make sure yours are there and aren't worn out or collapsed
