V6 to LS1 SS swap
I'm working on an LS1 swap into a 2002 V6 base model camaro. The LS1 is from a 2002 SS Camaro. What all needs swapped over besides the engine/trans? Is the suspension different?
There is a swap thread but I do not think it covers the LS1. You need the whole Kmember, all the wiring even into the Dash and the dash cluster, you need the entire cooling system, Fuel lines and sending unit/pump. Everything the is connected to the motor you need, If you have the chance you want to grab the rear also.
The 2002 will plug right into the body harness without any issues. I would just swap to a 155 mph cluster for obvious reasons ;) The suspension should be the same besides the kmember.
3.4/3.8 V6 to LS1 |
Originally Posted by Gorn
(Post 680608)
Originally Posted by ahaas91
(Post 680628)
The radiator from the SS is broken. Anyway to make that work with the V6 radiator?
must have been to much ,looking for swaps on this forum 95 to 97 probley not is my guess
