thetal1's 95 383 ls1 build
#21
For future reference, take LOADS of pics of install, wiring, etc. It could prove to be very helpful to people searching for swap info. I would definitely refer to it when its time for my swap.
#24
so while i was putting on the oil pan i made a mistake of seein in. lbs and thinking it was ft.lbs so i broke that bolt into the rear main cover. Lucky me it was an easy fix after i took the oilpan off a few days later (i had to calm down from almost ruining my engine) part of the bolt was sticking out. After that fiasco i got all the pretty pieces on and torqued to the correct amount. Then i finally put those GO FAST parts on and the ls6 intake.
#25
so finally i got to see what the factory injectors looked like compared to the racetronics and there is a big ol difference. After getting the fuel rail on and all the finishing touches i decided to move on to the next best thing a FULL gas tank
#27
so after all the excitement i got the new ls1 fuel tank in with my racetronics fuel pump and hot-wire kit installed. Then i finally ripped out the old wire harness and laid the new one in its place. Also some of my local club members put together the tubular-k and helped me run the ls1 fuel lines.
