project 9 second lt1 (4th gen)
Old 06-23-2009, 03:07 PM
cbr600rx7's Avatar
Good pick going with the ford 9 that should hold up to all the abuse you can put on her. I might have missed it in the last 21 pages but are you keeping the T56 and what are you doing to beef her up.
I cant wait to see that thing run man. You let me know when and where because if its in NC im going to be there to see it.
What are you doing for track tires and rims.
  #212
Old 06-23-2009, 06:56 PM
z28rob18's Avatar
the trans im gettin a new main shaft (stock just new) new second gear there weak in the early trans' then probably little things like forks pads. its not a good thing but im tryin to keep the trans 500 or less spent. wheels greg weld fronts 15x3.5 i believe and i have jegs stars for the hoosiers and greg welds for street both 15x8. and i plan to race it down in NC while im at school. but off the juice itd be wierd keepin a n2o bottle in the dorm.
  #213
Old 06-23-2009, 07:59 PM
cbr600rx7's Avatar
Where do you plan on going to school at down in NC. As i am sure you know the rock is one of the best tracks on the east coast. You also have the Fayettvile track that is cheap and not bad for test and tunes since it is a lot smaller. I have this set of prostars sitting with a set of MT slicks if you need a set.
  #214
Old 06-24-2009, 06:04 AM
z28rob18's Avatar
im goin to high point university in high point lol ill probably look for a class to run in on weekends
  #215
Old 06-24-2009, 12:16 PM
cbr600rx7's Avatar
Hmm not sure where high point is.
Have a few quetions.
What kind of CR are you running on this thing?
What kind of delivery are you using for the nitrous?
Why 3.90s?
What size injectors?
  #216
Old 06-24-2009, 12:17 PM
cbr600rx7's Avatar
Your suspension set up should be good for 9 second passes. And thats one hell of a rear end that should hold up to just about any thing. My worry would be in the T56 and running a 200 shot off the line on slicks. Its going to be very hard on 2nd gear.
  #217
Old 06-24-2009, 12:48 PM
z28rob18's Avatar
im workin on gettin trans parts now. and compression is 11.6.1. if i said 3.90 in there i messed up there 3.70 gears and im using them because with the 27" tire from wat the calculator said they will be almost perfect i hav a set of 4.30s that came with the rear but id run out of gear with them. the n2o will be sprayed through a single nozzle till i upgrade to a DP and i may be piecing together a dedicated. im goin to get a micro edge controller so if i need to i can put on a delay and wat not.
  #218
Old 06-24-2009, 02:04 PM
z28rob18's Avatar
cbr y do you mention second gear? is it really that much weaker in the 93-99 t56's?
  #219
Old 06-24-2009, 02:59 PM
cbr600rx7's Avatar
Run out of gears on a six speed?
What kind of RPM do you plan on turning?
What size shot?
Do you plan on spraying the car for the full pass (off the line)?
  #220
Old 06-24-2009, 03:12 PM
z28rob18's Avatar
in the 6th speed 5th and 6th r overdrive. so it kinda just falls off if you have to end the run in 5th. so you gotta calculate it to be at the top rpm in 4th by the finish line. cam should peak around 6600-6800 200 shot and yes i plan to spray gears 1-4
Quick Reply: project 9 second lt1 (4th gen)
