My 96 RS build.
20 Attachment(s)
02/2005 1996 RS 60k miles
Attachment 19188 Attachment 19189 Attachment 19190 Attachment 19191 new front nose emblem Attachment 19192 bad choice with billet grille Attachment 19193 another bad choice on flowmasters and rear euro markers Attachment 19194 black outs Attachment 19195 inatke and first STB Attachment 19196 no pics 32/21 1LE sway bars with poly bushings and endlinks interior change neutral to ebony and wrapped dash parts. Attachment 19197 Attachment 19198 Attachment 19199 Attachment 19200 Attachment 19201 Attachment 19202 Attachment 19203 Attachment 19204 Attachment 19205 Attachment 19206 Attachment 19207 |
4 Attachment(s)
and RED LEDs
Attachment 19184 new wheels and tires http://i203.photobucket.com/albums/a...s/d7c8af39.jpg berger mod Attachment 19185 Attachment 19186 eurolights with HIDs 6k Attachment 19187 |
7 Attachment(s)
Borla goes in, with corsa clones
Attachment 19177 dyed top Attachment 19178 Attachment 19179 3 point Kenny Brown STB Attachment 19180 other parts with no pics new J&M Panhard J&M LCA's 3 piece poly-ball bushing UMI SFC's poly bump stops new hood Attachment 19181 finally a tonneau cover Attachment 19182 Attachment 19183 |
10 Attachment(s)
3 Attachment(s)
Well after wasting around 3hrs or so, trying to get a lifter out of the oil pan, that I forgot to take out. The new GT2 cam and JP performance timing chain set are finally in. Maybe next weekend we can start this baby up........=:-)
Attachment 19164 Attachment 19165 finished the intakes Attachment 19166 https://sphotos-a.xx.fbcdn.net/hphot...96492592_n.jpg https://sphotos-a.xx.fbcdn.net/hphot...76409542_n.jpg https://sphotos-b.xx.fbcdn.net/hphot...03374551_n.jpg https://sphotos-b.xx.fbcdn.net/hphot...66375800_n.jpg |
and where its at now
http://i203.photobucket.com/albums/a...2/IMG_5988.jpg http://i203.photobucket.com/albums/a...2/IMG_6001.jpg http://i203.photobucket.com/albums/a...2/IMG_6000.jpg http://i203.photobucket.com/albums/a...2/IMG_6140.jpg http://i203.photobucket.com/albums/a...2/IMG_6164.jpg http://i203.photobucket.com/albums/a...2/IMG_6162.jpg 1996 Camaro RS Convertible Exterior Color: Arctic White Interior Color: Netuarl Leather Engine: 3800 Series II V6 Transmission: Automatic 4L60E Factory Options: Fully Loaded Exterior modifications: -Harwood 2.5" cowl hood -Black carbon fiber nose emblem -Berger mod with white camaro emblem inserts -Red Calipers Interior Modifications: -Ebony leather interoir swap -Red LEDs in dash -Custom vinyl wrapped dash and trim Performance: -Full cold air intake by chromeintake's -GT2 Cam 216°/216° at .050" Intake Lift .317" (.507" lift at 1.6:1 rocker ratio) Exhaust Lift .317" (.507" lift at 1.6:1 rocker ratio) 111 LSA -LS6 #90 yellow springs -Comp pushrods 7.05 5/16 .080" thickness -Viton Valve Seals -INTENSE Re-usable Rocker Arm Bolts -JP Performance Single Timing Chain -Manley Performance Valvespring Retainers -Comp OE lifters -Pacesetter Headers -Borla PRO XS -4" Corsa Clones -NGK TR55 spark plugs -MSD 8.5MM Super Conductor Ignition Wires #32799 -180 Thermostat Suspension: -UMI red SFC's (weld-in's) -Kenny Brown 3 point STB -J&M LCA's 3 Piece Poly Ball Bushings (red) -J&M Panhard Rod (red) -32mm 1LE Front Sway Bar (black) -32mm Prothane bushings (red) -Front Energy Suspension End links set (black) -21mm 1LE rear sway bar (red) -21mm Prothane bushings/end links set (red) -red ploy bumpstops Wheels/Tires -17' SS 10 spoke wheels -275/40ZR17 Riken Raptors Brakes: -Slotted and cross drilled rotors Electronics: -SLP Fan Control Switch -Pioneer DEH-P7700MP Head Unit -Blaupunkt GTc652 6-1/2" Component System -Blaupunkt GTx662 6-3/4" 2-way Speakers |
wow, awesome build. I love the look of the car, very tastefully done.
Yea, AWSOME job on everything, keep up the goodwork and keep the pics coming. Huge difference visually. Have you been able to drive it yet? If so notice the difference in performance?
car looks fantastic, definitely a lot of work involved there
(Post 631471)
Originally Posted by Bandit 43
(Post 631491)
BTW, my car dyno all stock at 170.9 rwhp, and the GT2 cam and mods that I have usually dyno around 225-240 rwhp, I've seen a few with higher numbers, that have been able to get a reall live dyno tune.
Originally Posted by Cheeks
(Post 631525)
| All times are GMT -5. The time now is 08:06 AM. |
