-   93-02 Projects (https://camaroforums.com/forum/93-02-projects-109/)
-   -   Lt1 motor mounts (https://camaroforums.com/forum/93-02-projects-109/lt1-motor-mounts-88029/)
Kimdylmk May 25, 2025 07:01 PM
Lt1 motor mounts
I’m doing an engine swap on my 95 v6 Camaro to a lt1 and I can’t seem to figure out the motor mounts. Do I just drill new holes into the frame or is there a special motor mount I should be using? And if I do need to drill new holes how do I get a nut onto the other side of the bolt? I don’t see how I could access it. Any help would be greatly appreciated
cwilt May 25, 2025 09:33 PM
I believe you have to swap the K member for a V-8 to be installed into your original V-6 car. Lots of posts and info out there.
craby May 26, 2025 03:52 PM
need to change the k member, and springs. unlike the 3rd gens the 4th gen v6 is not designed for a v8 at all.
