Power windows and locks?
yes. im sure you can pick up the door trim panels, motors and track and make your own wiring harness. there may be a kit, but im not positive
I know they make power window kits for my 80 camaro so they should make them for your 01 in fact i found the window switches on www.ecklerscamaro.com but i didnt find the motors for them. i found power window regulators on www.paddockparts.com for $180 apiece. it says they are for firebirds so you may want to call them and find out if it will fit your car.
you can always try to salvage the parts from a yard but there is no guarentee that they will still work but if you do,make sure you get both motors, tracks switches and relays. You might even be able to get the power locks from the same car however, my brother just got power locks for his ford ranger and they came with an alarm set that has keyfobs for the locks and a remote start. it only cost him $140 total for the locks remote start and alarm installed.
Good luck hope i helped some.
