Power window doesn't roll down after replacing window motor
Old Jul 23, 2014 | 11:49 PM
cornmuffin's Avatar
Default Power window doesn't roll down after replacing window motor
Hi there,
My passenger side window was moving sluggishly and then finally stopped working in the up position (thank goodness). I though it was the motor, so I bought a replacement and installed it. During the test, before I mounted the new one, I noticed that the motor worked by pressing up on the door switch, but not down. The same goes for the switch on the driver's side door.
So the problem wasn't that the motor failed, but it couldn't roll back down. I am not sure where to go next. I'll mention again that the roll down switch on both doors did not get signal to the window motor.
Thanks!
Old Jul 24, 2014 | 08:43 AM
what year and model?
Old Jul 24, 2014 | 09:47 AM
cornmuffin's Avatar
2000 camaro, base model
Old Jul 24, 2014 | 10:22 AM
ok, im not as up to speed as i should be on the 97-02. heres a link that you can download a wiring diagram for your year. can also download the factory service/shop manual, fb99 folder would be the one that is pretty much like yours. i believe the windows on the 99 go through the body control module, bcm but that usually also effects other parts of the system, like the radio.
http://www.mediafire.com/?40mfgeoe4ctti
Randy Bilyea
Jan 15, 2013 08:33 AM
Triangle12
Apr 21, 2012 08:11 PM
Jerry95lt1
Nov 29, 2010 07:59 PM
camaroglen
Aug 28, 2010 08:58 AM
jml2002
Jul 26, 2007 11:22 PM
