How to replace your (Auto) shift knob (1995)
10 Attachment(s)
Step by step instructions on how to replace your automatic shift knob with an aftermarket replacement:
For the aftermarket knob, I used a custom one from SickSpeed Total cost less than $100, shipping included, and that also includes the hat pin that I sent them to embed in the knob. We will start with this: Attachment 17141 On the front side of your shift knob (facing the front of the car) there is a small indentation that holds a clip to hold the knob on the shaft. Carefully remove the clip. You may have to pick at the leather wrap a bit to get it out of the way, or if you never plan to use the OEM knob again, simply cut the leather off to get at the clip like I did. Attachment 17142 Once you have removed the clip, pull straight up on the knob to remove it from the shaft. It is still VERY tightly on there. It takes a fair bit of force to remove it. With the knob removed you will have a metal shaft with a plastic insert exposed: (note, I have already trimmed the plastic insert in this pic, yours will be longer than this!) Attachment 17143 You will need to trim the metal shaft down by about 1 1/4" I used a regular tube cutter for this so as not to damage the interior plastic shaft formerly used by the release button. Attachment 17144 NOTE: when you first cut the steel shaft it will be VERY hard to remove from the plastic shaft. The tube cutters will compress the edge of the steel onto the plastic. CAREFULLY wiggle and twist it back and forth while pulling upward on the cut piece. This will eventually get it up and over the plastic shaft. You will now notice that your plastic shaft no longer moves up and down in the steel tube. PANIC! Actually, don't. Again the steel has compressed from the tube cutters. Get a small hammer and GENTLY tap town on the plastic shaft until it moves in the steel tube. It will shave a bit of the plastic off as it moves. Once it has moved down a 1/2" or so, grab the plastic with a pair of pliers and pull it back up again. Repeat this motion until the shaft moves freely and you are getting a bit weirded out by the motion. You will now need to trim some of the plastic shaft off the top as well. About the same amount as you took off the steel shaft. When you are done, it will look something like this: Attachment 17145 That was the hard part. (not too hard, was it?) Now, simply slide the knob with the adapter over the shaft fully, and tighten the set screw with the provided allen key, immediately stripping the tiny, weak, lame set screw. Attachment 17146 Go grab another set screw from the package it came with (you WERE wondering why it came with 3 set screws, now you know...) and GENTLY tighten it in, ensuring that the logo/whatever you put on the top of the knob is correctly aligned. It should look like this when you are done. Attachment 17147 Attachment 17148 Attachment 17147 Attachment 17150 Total install time, less than 15 minutes. |
Thanks for this
linked to in the how to and faq sticky
Forgive me for asking this but, Im assuming when you need to go from Park, to D or any other gear, you push down on knob to do so right? Im just curious because the stock shift knob has the button on the top to be able to put the car into the other gears.. I would like to do this mod in the near future but want some more insight... looks awesome tho, great job
i think it is down all the time, a while ago darlingreject did one and im pretty sure it was set up so the whole knob goes down to unlock shifter.
1 Attachment(s)
after looking closer i see it looks like it slides up and down enough to push the shifter down.
Attachment 14920 |
Originally Posted by craby
(Post 672930)
http://i138.photobucket.com/albums/q...IMG_7997-1.jpg |
