Help with door handle light...
Ok - someone had my '96s doors apart before me, and I have this blown bulb and socket hanging loose. It looks like a neo-wedge type base (which is all that's left). I'm not sure where it mounts, but I'm guessing it's there to light up the door window/lock switches. Any clues as to where/how it mounts? I have a parts diagram, but that's of no help.
Thanks!
Thanks!
RE: Help with door handle light...
That's odd - from the .pdf I got of the factory parts list, it looks like it is there - has part numbers and everything.
I take it that "SI WDO SW BULB"means "Side window switch bulb", hence the question.
ORIGINAL: traumadog
Thanks!
Thanks!
ORIGINAL: Ozzker
My '94 has them!They areburnt out and I'm too lazy to take the door panel off to replace them, but they are there I have seen and removed them before!!
