gauge swap
i have a 95 camaro, with the 3.8 v6.. it has a 115 mph speedo in it right now.. but i can bury the needle.. is there any way i can just install a z28 gauge cluster instead?? would i need some kind of an adapter or anything for the wiring??
RE: gauge swap
as long as you get a fourth gen cluster it should fit and wire perfectly. i'm not positive but i'm pretty freakin sure. sick
RE: gauge swap
Hey i have a related question but about the 3rd gen camaros. Is there any way to swap the digital gauge with a regular gauge cluster????
RE: gauge swap
I too have a question about the 3rd gen gauges, i have an 85TA and it only goes up to 80mph, would any thirdgen gauge cluster work>? im not concerned about the odometer because the engine has less miles than the body/odometer says.
Thanks |
RE: gauge swap
camaro... i take it you have the berlinetta? if so i do not think it is possible to change out the gauge cluster to the needles. You can check around. but ive never heard of it. As for AS for Celtics, if they are ANYTHING like camaros,,, you could pick up the TA cluster off anything from a 82-89 i believe. They switched to the electronic gauges in 90 from what i have heard.
| All times are GMT -5. The time now is 04:49 AM. |
