93 Z28 windows and radio stopped working
Old 04-22-2018, 07:03 PM
Madhatairsoft's Avatar
Default 93 Z28 windows and radio stopped working
My 93 Z28 has decided to stop with the windows and radio working. I am lost now have new fuses in new switches put in checked fuse box and have no power at the relay for defogger and windows plus the crank fuse has no power also but car starts right up with no problems please someone help
Old 04-22-2018, 07:29 PM
MKCoconuts's Avatar
Check the circuit breaker. I believe the windows have one. Rare for one to go bad, but not impossible. Also, check power at the switch and when activating it
Old 04-22-2018, 08:09 PM
Thank you I have checked power at both switch and fuse/breaker no power at both replaced both and still no power it's really frustrating because there is no A/C so I at least need my windows down to cruise it gets hot in there
Old 04-22-2018, 09:32 PM
peterpar's Avatar
If you have no power at either of these fuses in the IP fuse block, chances are there could be a problem with the RAP module if your car is equipped with the RPO KP2 or contacts in the ignition switch. I've attached troubleshooting charts from the 1993 Firebird Service Manual that may help. Pretty sure the diagrams will be the same as the Camaro.
File Type: pdf
Old 04-23-2018, 07:10 PM
MKCoconuts's Avatar
Gonna have to trace wires and find where you're losing power. Also, check cigarette lighter fuse, radio gets power through there.
Old 04-25-2018, 03:26 PM
Chaotic94's Avatar
September 2011 ROTM
Sounds like a cracked solder joint in the BCM. My buddies car did this and I just re-soldered the cracked joint in the BCM and it was good to go.
Old 04-25-2018, 04:33 PM
peterpar's Avatar
I don't believe the 93-95 models were equipped with a BCM. This function was controlled by the RAP module in 93. A cracked solder joint may still be the problem, but not sure if the module is serviceable. Starting in 1996, the BCM was added and the RAP module was included it.
Old 04-25-2018, 05:10 PM
Chaotic94's Avatar
September 2011 ROTM
^I was unaware of that. You learn something new every day lol.
shinwolf14
09-29-2010 12:39 AM
Nite
09-13-2009 07:07 PM
AmirGTR
05-01-2009 10:43 AM
81zedder
05-31-2008 11:12 PM
DJTJ
03-27-2008 10:45 AM
Quick Reply: 93 Z28 windows and radio stopped working
