1999 Camaro Bright Switch not engaging
Old Jul 28, 2013 | 05:13 PM
yep you need the key with the right ohms or bypass vats.
Old Jul 28, 2013 | 06:06 PM
PatrickM's Avatar
So am i able to just take tge old key with to the dealer or locksmith? Also when i was using the tool to decompress the lock plate, it wouldnt compress so i took it out and under the spring theres is a nut or something that was holding it back and it bent and is no good... Is it called the lock plate insulator? And also any ideas on where to buy one?
Old Jul 28, 2013 | 08:04 PM
PatrickM's Avatar
I took a pic for anyone that might be able to tell what this is called? Like I said it is behind the spring for the Lock Plate, and as i was compressing you can see it got a little caught up. Thanks
Attached Thumbnails 1999 Camaro Bright Switch not engaging-photo-2.jpg   1999 Camaro Bright Switch not engaging-photo-1.jpg
Old Jul 28, 2013 | 09:36 PM
can you see it here
Size:  67.3 KBName:  PB070007-1.jpg
Old Jul 29, 2013 | 01:47 PM
PatrickM's Avatar
Alright so its called the upper bearing inner race seat, would you happen to have an idea on where to purchase one? I've looked at RockAuto, and the GM parts Online and no luck.
Old Jul 29, 2013 | 03:08 PM
shows it as part of kit 2 part #26016805 woh 55 bucks here SPRING KIT. Steering Column. 1994 Buick Regal # 26059718, 26016805
Old Jul 29, 2013 | 03:20 PM
being this is for a 99 and i have a 93 book we better look the part number for the 99 to see if its right.
Old Jul 29, 2013 | 03:34 PM
yep they are the same part. 97-02 26059718
Old Jul 29, 2013 | 08:28 PM
PatrickM's Avatar
Alrighty I ordered the part along with a pair of keys I found off of ebay with the same resistance number. Should be here within a week and ill let you know how everything works out. Thanks for your help!!
Old Jul 29, 2013 | 10:31 PM
  #20
PatrickM's Avatar
Actually before i order the keys i was looking them over and the ones im looking to order have the chip on one side, whereas my original key has it on both sides. Does that matter?
