Wiper motor help
So I replaced the wiper motor and when I use the mist the wipers were a little jerky, would stop about half way for a split second. Now they’re stuck in the up position. Any ideas? Thanks
did you replace the whole unit? the wiper brain/circuit are usually is the issue with this problem. you may have gotten a bad unit if the whole thing was replaced
I did replace the whole unit. Pulled the motor back out this afternoon and the motor is shot. Just spins freely.
