windscreen wiper motor problems
hi guys im new to this, so my problem is as follows, I recently have had to change my wiper motor as the original was only working intermittently so got a replacement from a z28 but the linkage to motor link was bent so I had to remove and replace it now the wipers work until you fit the arms then it pops the linkage on the motor and the linkage end, im thinking I haven't got the arm on the motor right and its causing problems with the park, does anyone have any thoughts
have a look here and see if it helps
https://camaroforums.com/forum/93-02...rmation-66130/ |
