Window water....
a bullet broke the passenger side window, I replace it.
but when I spray water on it from out side the upper left corner is leaking to inside
wish one i should adjust
parallel to the weatherstrip assembly or forward or rearward?
Adjust Door Window
Adjust Door Window
For me adjusting the window was kind of a trial and error thing. Try one adjustment, check it, if it helped great, if not move it back. Once you get a feel for what the different adjustments do, you should be able to figure out which ones will fix your problem.
"a bullet broke the passenger side window, I replace it.
wish one i should adjust"
People who had to replace their door motors have the same problem. It's not easy, it's make an adjustment and see if it helps.
Guys, look at his location. A bullet breaking his car's window is trivial compared to the crazy sh%& going on around him on a daily basis. I'm surprised that he has time to sit at a computer and power for it to work! Or that *he's* not the one wearing the bullet hole.
cornmuffin
Jul 24, 2014 10:22 AM
