Window Trim fix suggestion
Old Jun 14, 2010 | 01:31 PM
zombie's Avatar
Default Window Trim fix suggestion
Wasn't bad until late and it is small but annoys me - the trim at the top of the door/bottom of window is lifting up in some places like the windows are pushing it...
not greatest pic but shows piece I am talking about...the metal clips are up completely in some spots.
My search fu may be failing but couldn't find any fix or way to correct this as I don't want to break anything or mess up the paint as it's in remarkable shape
Old Jun 14, 2010 | 02:12 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
yeah you have to go buy new clips.... autozone can order them for you and then you just push them back down in there... if its all rust and shreaded down there a buddy of mine took tiny tiny little screws and did it that way, but be careful the door is made of fiberglass and will crack
Old Jun 14, 2010 | 02:22 PM
zombie's Avatar
awesome - good to know nice and simple - minor thing but major annoyance to me. Happen to know part number or price odd hand?
I have spotted no rust
Old Jun 14, 2010 | 02:37 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
no part number... i did it like 3 years ago on old camaro but i think it was like $10 for both sides... it was cheap
Old Jun 14, 2010 | 03:02 PM
zombie's Avatar
awesome. You are a life saver. I will stop being lazy and see if I can find out the part on their site
Old Jun 14, 2010 | 03:08 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
good idea... you get lazy and your car gets decrepid... gotta keep up on them lol
Old Jun 14, 2010 | 03:12 PM
zombie's Avatar
yeah...I know all about decrepid cars - got a 68 ranger (full size) needing a motor and tranny - and a 93 civic that smokes needing re sprayed
my suburban and camaro look good though
as you replaced before this look like what you bought?
http://www.autozone.com/autozone/cat...oductId=854702
Old Jun 15, 2010 | 05:20 PM
let us know how the aftermarket window seal works. i replaced the inner seal and the pads and it made a big difference, the window doesnt rattle and wiggle around anymore. make sure its not your door skin coming lose, that has happened on the driver side door on both the 93 z28s ive owned. this one is just starting to come lose so i havent reglued it yet.
Old Jun 15, 2010 | 10:03 PM
Massey's Avatar
alot of the time you can just pull the weather strip and re set it back in place. You will need to remove the mirror pull up the moulding and fix any clips that have been bent out of shape. Usually they just need to be pushed back in. when you put the moulding back in make sure that the long part of the clip does not go into the hole in the door skin. That is for the moulding clips to grab onto not go into. you kinda gotta get them all lined up and in the slot then I usually start at the rear of the door and push them in one clip at a time. When you get to the part under and in front of the mirror get a block of wood (I use a 1x4) and a hammer and lightly tap it back in. (the mirror post will fight the moulding). Reinstall the mirror and bingo you are done.
The strips you looked up at autozone are not the ones that will work with our cars. They are for the trucks and/or generic. The mouldings for the camaro are very specific and you need to use one from our cars to get it to fit right.
Massey
Old Jun 16, 2010 | 11:08 AM
DarkKnight's Avatar
GTO Killer
LimeKnight
yeah i didnt get whole strips... just new clips, and autozone did have those
